Grounded Bushing Support
Type of connection used to constrain a part to the ground
Unlike a regular bushing that connects two parts, a grounded bushing provides stiffness, damping, and inertial properties between a single part on an assembly and a fixed, external reference (the ground). This is useful when modeling complex supports or foundations that exhibit flexibility, damping, or mass characteristics. The grounded bushing can be applied to faces or spots on a part.
Create
  1. In the Project Tree, select an analysis subcase (structural, modal or structural multi-loadcases) to open the Analysis workbench.
  2. In the Analysis Workbench, select Constraints > Grounded bushing support.
  3. Under Apply to, select the Face or Spot radio buttons.
    If Spot is selected, new spots can be created by clicking Create new spot.
Once the face or spot is selected, define the bushing's properties.
Define
  1. In the Coordinate system tab, define the following.
    1. By default, Origin is set at the center of gravity (COG) of the selected entity. To manually define the origin, uncheck the Set in COG checkbox and enter the desired X, Y, and Z coordinates.
    2. Select the axis that will define the orientation of the bushing's stiffness, inertia, and damping properties. Then specify the X, Y, and Z direction vectors for this axis.
  2. Go to the Stiffness tab and define the following.
    1. Input values for the Linear X, Y, and Z translational stiffness.
    2. Input values for the Angular X, Y, and Z rotational stiffness.
  3. Go to the Inertia tab and define the following.
    1. Enter a value for the bushing's Mass.
    2. Specify values for the X, Y, and Z moments of inertia.
  4. Go to the Damping tab and define the following.
    1. Input values for the X, Y, and Z translational damping.
    2. Input values for the X, Y, and Z rotational damping.
  5. Once all parameters are defined, click Apply to create the grounded bushing constraint.
    The virtual connector appears in the Connections branch. If selected, vectors representing the connection in the modeling window are displayed.
    Note: A grounded bushing with damping is only supported for complex eigen value analysis. The running modes automatically run complex modes.
