Cable/Rod
Combines the functionality of creating virtual cables or rods with the ability to apply change in length
This tool creates a virtual cable or rod with finite or infinite stiffness between two spots, either on different parts or between a part and a fixed ground point.
  1. In the Project Tree, click on a Structural analysis branch to open the Analysis workbench.
  2. In the Analysis Workbench, select Constraints > Cable/rod.
    Note: For modal, structural/modal superelement export analysis, and multi-load case, only rod is supported.
  3. Select a Type from one of the following:
    • Cable: Resists only tension.
    • Rod: Resists both tension and compression.
    • Grounded cable/rod: Connects a spot to a fixed ground point.
  4. To define the End(s), do one of the following:
    • For Cable or Rod, select two spots for End1 and End2.
    • For Grounded Cable/Rod, select a spot for End1 and then manually enter the coordinates for the Ground point.
  5. Define the Stiffness of the connector. For an infinite stiffness, select the Rigid checkbox.
  6. Optional: If pretensioning is not required, select the No preload radio button. Skip to step 8.
  7. Apply pretensioning.
    This feature allows you to define a change in length for a virtual cable or rod. This is used to simulate pretensioning.
    1. Select the Cable/Rod length change radio button to input a value.
      Note: This option is active only when the Cable/Rod definition is completed.
    2. In the dialog, choose the appropriate option and set the value:
    • Define the length change for a cable as an absolute value or a relative percentage.
    • Define the length change for a rod as an absolute value or a relative percentage.
  8. Click Apply to create the constraint.
    The constraint will appear in the Project Tree under the structural subcase.
Important: A negative input value indicates compression (shortening), while a positive input indicates elongation (tightening). Click OK to apply the preload. For Rod, both positive and negative inputs are supported, whereas for Cables it is always positive input.
