- Immovable Support
Enforce zero translational displacements in all directions on faces, edges, vertices, and/or spots.
- Slider Support
Enforce zero displacement in normal to the surface direction on faces and areal spots.
- Hinge (Pivot) Support
Connect faces or spots to a ground support.
- Spring Support
Set an elastic foundation at selected faces.
- Virtual Spring Support
Create a virtual spring support with finite stiffness and spring force between two different parts or between a single part and ground. Springs can be applied on both faces and spots.
- Grounded Bushing Support
Type of connection used to constrain a part to the ground
- Cable/Rod
Combines the functionality of creating virtual cables or rods with the ability to apply change in length
- Shock Absorber
Used to simulate damping and stiffness behavior in assemblies
- General Constraints
Constrain displacement of faces, edges, vertices, or spots in Modal analysis.
- Alignment Constraints
