Virtual Spring Support
Create a virtual spring support with finite stiffness and spring force between two different parts or between a single part and ground. Springs can be applied on both faces and spots.
  1. In the Project Tree, open the Analysis workbench.
  2. In the Analysis Workbench, select Constraints > Spring.
  3. For Type, select Spring or Ground spring.
    TypeDo this
    Spring
    1. Select End1, and then select the faces or spots of one part.
    2. Repeat for End2.
    Note:
    • Multiple faces or spots that belong to a single part can be selected for each end.
    • The Check COG option is activated by default. Uncheck the option to manually change the coordinates of each end.
    Ground spring
    2. Switch to Ground and then enter the coordinates of the ground point.
  4. Define Stiffness and Force.
  5. Click Apply.
    The spring will appear in the Loads and constraints branch. If selected, the vectors representing the spring in the modeling window will appear.
