Bolt/Nut Tightening Loads
Available for blind bolts (bolt without a nut), bolt with nut/bolt on threaded rod, nut on generic post or handle.
- In the Project Tree, open the Analysis Workbench.
In the workbench toolbar, click
(Bolt nut
tightening).
- Select the supported parts.
- In the dialog, specify the Thread pitch.
- Activate the desired Bolt/Nut tightening method radio button and enter values in the text fields.
- Specify the Torque and Force units.
- Click OK.
