Temperature
In thermal analysis, limit temperature on the selected faces, edges, vertices, or spots to a prescribed value.
For steady state thermal analysis, the temperature input is the temperature difference (Tfinal - Tinitial). For thermal transient analysis, it is the final temperature.
- Int the Project Tree, click the Thermal branch to open the Analysis Workbench.
                On the Analysis Workbench toolbar, select
 (Temperature).
             - In the dialog, use the radio buttons to select to what entity the spot will be applied.
 - In the modeling window, click to select specific parts on the model.
 - Optional: If applying to Spots, create new spots by clicking Create new spot.
 - Optional: You can select the Add tangent faces check box.
 - Specify Temperature change units and value.
                Click OK.
                The load will appear in the Thermal branch under Thermal conditions. Once you have applied temperature, the application then determines the temperature at every location of your model for which you have not prescribed it.
