Gravity Load
Simulate the force of gravity as it affects your model.
- In the Project Tree, open the Analysis Workbench.
In the workbench toolbar, click the
(Gravity load) icon.
In the dialog, specify directional components of the load in the X, Y, and Z
fields.
Note: Enter negative values to specify gravitational forces that oppose the coordinate direction.
Specify amplification factor for the gravity load magnitude.
Note: The default magnitude is specified as a ratio of 1G gravitational load.
- Click OK.
