Immovable Support
Enforce zero translational displacements in all directions on faces, edges, vertices, and/or spots.
- In the Project Tree, open the Analysis workbench.
- In the Analysis Workbench, select .
- Specify which type of entity will have constraints applied.
- Optional: If applying to Faces, you can select the Add tangent faces check box.
- Optional: If applying to Spots, create new spots by clicking Create new spot.
- In the modeling window, click to select specific parts on the model.
- Click OK.
