2022.3
Interfaces that support SimSolid output file format.
View new features for SimSolid 2022.3.
Discover SimSolid functionality with interactive tutorials.
Use material data from Altair Material Data Center in SimSolid.
Use loads from Altair EDEM in SimSolid analysis.
Use Altair Inspire with the SimSolid solver to quickly create and analyze new designs.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
