Altair Material Data Center
Use material data from Altair Material Data Center in SimSolid.
Export Material Data
Export material data from Altair Material Data Center.
- Log in to your Altair One account.
- Open the Material Data Center.
In the Filters list, under Software, select SimSolid.
Materials available for import to SimSolid are displayed.
- Double click on a material or select the Details.
- In the information window, select the CAE Model tab.
Under Select Software, choose SimSolid from the
drop-down menu.
- Click Download.
Once downloaded, unzip the files.
Note: Materials with an associated stress-strain curve contain two files; one contains material data and the other contains the stress-strain curve data.
Import to SimSolid
Import material data from Altair Material Data Center.
- Launch SimSolid.
- On the main menu, select .
- In the pop-up window, choose Edit current.
- In the Edit material database window, select a material group.
- Click Import from CSV.
Navigate to the file with a name ending in
_head.csv.
The material is imported to the material group specified in the .csv file.
- Click Save to store the material in the SimSolid database for future use.
