A Spots is a feature that enable applying loads, constraints, or other boundary conditions (BC) to local regions on
the surface, instead of applying BC to the whole faces of the model
Rigid Parts
A rigid part can displace under the loading, but only as a rigid body, i.e. without deformation or strain.
Spots
A Spots is a feature that enable applying loads, constraints, or other boundary conditions (BC) to local regions on the surface, instead of applying BC to the whole faces of the model
Create Coordinate System
Define a local coordinate system to which boundary conditions may be later applied.
Create Line on Part
Create a line that can later be used to generate seam welds.
Create Sheets
Create a sheet from an imported surface by applying thickness.
