Available Boundary Conditions for Analyses
A comparison chart showing the available boundary conditions for each analysis type.
An "X" indicates the boundary condition is available for the analysis type. An empty cell indicates it is not available.
| Boundary Condition | Structural | Multi-loadcases | Modal | Dynamics | Frequency Multi-loadcases | Thermal | Electromagnetics |
| Immovable Constraint | X | X | X | ||||
| Slider Constraint | X | X | X | ||||
| Hinge Constraint | X | X | X | ||||
| Spring Support | X | X | X | ||||
| General Constraint | X | ||||||
| Grounded bushing support | X | X | X | ||||
| Cable | X | ||||||
| Rod | X | X | |||||
| Spring | X | X | |||||
| Shock absorber | X | X | X | ||||
| Alignment | X | ||||||
| Uniform pressure | X | X | X | X | |||
| Hydrostatic Pressure | X | X | |||||
| Wind load | X | ||||||
| Force/Displacement | X | X | X | ||||
| Forces | X | ||||||
| Gravity Load | X | ||||||
| Translational/Rotational Inertia | X | X | |||||
| Inertia Relief | X | X | |||||
| Remote Load | X | X | X | X | |||
| Remote Displacement | X | ||||||
| Thermal Load | X | ||||||
| Bearing Load | X | X | X | ||||
| Distributed Mass | X | X | |||||
| Bolt/Nut tightening | |||||||
| Volume Expansion/Shrinkage | X | ||||||
| Base excitation | X | ||||||
| Temperature | X | ||||||
| Surface Heat Flux | X | ||||||
| Thermal Convection | X | ||||||
| Volume Heat | X | ||||||
| Solar load | X | ||||||
| Perfect electric conductor | X | ||||||
| Waveguide port | X |
Imported Boundary Conditions from CSV
| Boundary Condition | Structural | Multi-loadcases | Modal | Dynamics | Frequency Multi-loadcases | Thermal | Fatigue | Electromagnetics |
| Pressure | X | |||||||
| Forces | X | X | X | |||||
| Spot Forces | X | X | X | |||||
| Spot Displacements | X | |||||||
| Remote Loads | X | X | X | |||||
| Temperature | X | |||||||
| Flux | X | |||||||
| Convection | X |
