Distributed Mass
Apply distributed mass across selected faces.
- In the Project Tree, open the Analysis Workbench.
On the Analysis Workbench toolbar, click the
Distributed mass.
Specify which type of entity will have mass applied:
- If applying spots, you can create new spots by clicking Create new spot or select existing spots.
- For faces, in the modeling window, select the
desired face(s) on the model.
- Optional: Select the Add Tangent Faces check box.
- In the drop down menu, specify Mass and Mass per area units.
Specify a value for Total mass or Mass per
area.
Note: Only Total mass is supported for Distributed mass on spots.
- For the entity type set to face, review the applied distributed mass details listed at the bottom of the dialog box.
- Click OK.
