Slider Support
Enforce zero displacement in normal to the surface direction on faces and areal spots.
  1. In the Project Tree, open the Analysis workbench.
  2. In the Analysis Workbench, select Constraints > Slider support.
  3. Specify which type of entity will have constraints applied.
  4. If applying to Spots, create new spots by clicking Create new spot.
  5. In the modeling window, click to select specific parts on the model.
  6. Click OK.
