Bolt and Nut Tightening Background Information
Bolt forces can be applied to bolt and nut geometries in SimSolid.
Bolts and Nuts
- Blind bolts
- Bolts with nuts
- Nuts on threaded rods
- Nuts on a generic post or handle
Relationship Between Torque M and Axial Force F
M is the maximum moment realized at the end of the tightening and it is equilibrated by moment from friction forces in contact between nut and the structure.
Assume for simplicity that normal forces in contact are distributed evenly, so the contact pressure is as follows:
R0 and R1 are inner and outer radii of the contact spot. Friction distributed force will be T=f∗P where f is a friction coefficient.
In a polar coordinate system, the elementary moment of the friction force with respect to the bolt axis is:
Integrate the elementary moment over the contact area to obtain the following:
Axial Force
Axial force depends on the structure and bolt stiffness, and on nut placement relative to the bolt:
Relative displacement can be expressed by the following:
Assume that at first analysis pass one nut turn is described (N(1)=1), and corresponded axial force F(1) is found from the analysis. The structure stiffness factor in this case can be defined as the following:
This implies: F=F(1)∗N .
Now you can relate torque to the number of turns:
Therefore, in order to realize prescribed torque M, after the first analysis is done with N=1, a second analysis (second convergence pass) must be performed using the following equation:
In general, at pass (i+1) the number of turns applied is as follows:
