Options
General
Update attributes after importing CAD models:This option automatically updates the attribute (Inspect | Attribute | Update) on importing the CAD model through File | Import | CAD or File | Import | CAD: Through Translation.
Operation on CAD body reflects on all its instances:On enabling this toggle, editing operation performed on CAD (Parasolid) body will reflect on all its instances. For example, defeaturing performed on one of the CAD (Parasolid) body will reflect on all of its instances.
Parasolid
Export version:
The export version for Parasolid files can be selected using this option. The latest version is the default option.
Split faces at high curvatureWhile importing Parasolid models, faces can be split along the high curvature by enabling the toggle Split faces at high curvature.
Fast importParasolid files can be imported faster by enabling the toggle Fast import. Here the face and edge tessellation may not match.
Exclude open faces from scribing
While importing Parasolid models or converting from native geometry to Parasolid, open faces can be excluded from the scribing process by enabling this option.
Note: The original file should not contain any pre-existing scribed lines.
