Display
File > Preferences > Geometry > Display
This is used to improve the Display Quality of CAD models during import. CAD Display Quality values can be varied as preferred, to achieve the desired output. Change the desired quality value and then import the model into SimLab to see the difference in display quality. The default values for respective CAD model types are as follows.
Parasolid
Default chordal deviation factor is 0.0001 and chordal angle is 22.5.
CATIA, STEP, SOLIDWORKS, Inventor
Default chordal deviation factor is 0.0001.
SimLab STEP reader
Default value for chordal angle is 18.00.
Pro/E chord height
Default value for chord height is 0.010.
