Spring(Beam)
Spring is created between any two faces or edges or nodes or bodies.
This beam-type spring property works as a beam element with six independent modes of deformation. This spring accounts for nonlinear stiffness, damping, and different unloading. Deformation, force, and energy-based failure criteria are available.
Cards supported for various solvers
| Solver | Supported Cards |
| RADIOSS |
/PROP/SPR_BEAM |
