Global Condition
Global condition is used to define common loads like gravity which is applied to the entire solution.
Note: Only one global condition can be defined for a
solution.The function multiplier is supported only for Radioss Drop Test solutions.
Cards supported for various solvers
| Solver | Type | Supported Cards |
| Radioss | Gravity | /GRAV |
| LS-Dyna | Gravity | *LOAD_BODY_VECTOR |
| OptiStruct | Gravity | LOAD, GRAV, DLOAD |
