Connect using MPC
This tool is used to create connection between the selected faces or between the covering and reinforced bodies using shape function based MPC.
Face to face connection
Reinforced body connection
- The coefficients of the MPC will be calculated based on the shape
functions.
- In case of face to face connection, the MPC will be created between node to shell element and this can method can be used to connect non-matching faces.
- For reinforcement body connection, the MPC will be created between node and solid element.
- Connect using MPC tool can be used for both structural and thermal solutions .
- Choose the finer mesh face / body as the dependent face, to have better connection between faces.
Cards supported for various solvers
| Solver | Supported Cards |
| Nastran/OptiStruct | MPC |
| Abaqus | *Equation |
