Edit Solution
Introduction
After to Edit the solution, it's possible:
- to assign all the meshed bodies to the solution.The bodies to be assigned to the solution:
- should be meshed with surface mesh or volume mesh (limitation to
be left)Warning: Before running the solving process, you will have to generate the volume mesh.
- should belong to the same .gda model
be left)
- possibly to modify the frequency definition i.e. the frequencies for which the computation will be done.
Warning: It is not possible to modify here the
simulation type and the port type: the corresponding fields are grayed out. The
simulation type and the port definition are only done during the creation of the
Parasitics Extraction solution.
Note: The Parasitics Extraction solution is created before, to
have more details about the creation of the Parasitics Extraction solution,
please refer to Parasitics Extraction solution.
Steps
- Double-click on the Solution button in the Solution Browser
- Select all the meshed bodies:
The outlines of all the bodies are displayed in red. All the bodies are going to be assigned to the solution.
- Possibly modify the Frequency definition
- Click on the OK button
