Motion
Introduction
The Motion allows you to define the motion of some bodies of the solution.
Dialog Box
| Translation type motion | Rotation type motion |
- Select bodies which are moving. At least, one body must be selected.
- Motion Type: Two choices are proposed:
- Translation
Translation direction has to be chosen through Define/Modify Direction button:
- Rotation
Rotation axis has to be chosen through Define/Modify Axis button:
- Translation
- Air type:
Two choices are proposed, available for both Translation and Rotation:
- Immersion in the air
This air type is chosen when the moving bodies are immersed into a large air volume.
It is mostly used for translating motion.
- Sliding airgap
This air type is chosen when the moving bodies are sliding with respect to the fixed part. The sliding surface is located inside the airgap and separates the airgap into two bodies: moving airgap and fixed airgap.
The following example illustrates it:Sliding airgap is mostly used for rotating motion, especially for motors.
