Imposed Current Coil
Analysis > Magnetostatic Loads > Imposed Current Coil
Introduction
The Imposed Current Coil allows you to define a body / bodies as a coil and enter the associated physical data.
Note: See Coils modeling for more explanations about the different possibilities of modelling of coils.
Dialog Box
Prerequisite: The bodies to define as Imposed Current Coils must be meshed.
  • Select bodies: Select one or several bodies to define as a coil
  • Number of turns: Enter the number of turns of the coil
  • Current value: Enter the current value
  • Conductor connection: is used if symmetry or periodicity entities are existing. This input allows to define the symmetric or periodic coils as in Series or in Parallel. That means that if a current "I" is flowing into the represented coil, then each symmetric or periodic coil will have:
    • in series: I
    • in parallel: I divided by the total number of coils in the complete device
      Note: for example, if the device has one symmetry, the current on the represented coil and in the symmetric coil will be I/2. If the device has a periodicity with a total of 6 portions, the current on each portion coil will be I/6.
  • Current orientation: allows to define the current orientation into the coil body. There are two possibilities:
    • Positive
    • Negative
