Infinite Region
Analysis > Magnetostatic Loads > Infinite Region
This tool is to define the study region in space for the magnetic analysis. User can see the preview of the infinite region in window.
For CAD based solution:
  • Infinite region will be stored as region data.
  • On mesh / update, Region data will be converted to CAD bodies.
  • Modifying the infinite region data, Delete the created CAD bodies if available.
  • The radius collected is the inner radius, The outer radius will be computed internally.
For Mesh based solution:
  • The mesh for the infinite region will be created within Flux.
Note:
  • Currently only disc type can be defined in SimLab.
