LS-DYNA Interface
New Features
- CONSTRAINED_INTERPOLATION_SPOTWELD
- CONSTRAINED_INTERPOLATION_SPOTWELD is now available as a point connector
type, which supports absorption, imprint, and realization.
- New Generic Impact Workflow
- The new Generic Impact tool has been added, which you can use to define impact points on any type of structural parts, automatically position any type of impactors, and automatically export ready-to-run solver decks. For more details, see the Safety Tools release notes.
Enhancements
- Contact Penetrations Check Tool
- Enhancements have been made in penetration calculation accuracy for
SOFT=2 (segment based) contacts and depenetration process performances.
The graphs in Figure 3, Figure 4, and Figure 5 show the drastic reduction of remaining penetrations after the
depenetration process for contact SOFT=2 for different large industrial
models within HyperMesh 2026.0 compared to HyperMesh 2025.1.
Figure 3.
Figure 4.
Figure 5.
- ALE Keywords Mapping
- LS-DYNA ALE keywords are now all mapped into a single entity, and no
more than eight different entities, for cleaner model organization and a
simplified future of ALE keywords support.
Figure 6. HyperMesh 2025.1
Figure 7. HyperMesh 2026.0
- Enhanced Material Anisotropy Definition for All Anisotropic Materials
- Node selection is no longer required to define (X1,X2,X3), (A1,A2,A3),
(D1,D2,D3), or (V1,V2,V3) anisotropy axis. It is now directly driven by
location selection or direction selection. You can also input each
attribute value manually in the Entity Editor.
Figure 8. HyperMesh 2025.1
Figure 9. HyperMesh 2026.0
- New Keywords Supported
- Support has been added for the new AIRBAG_CPG and
DEFINE_CPG_GAS_PROPERTIES keywords.
Figure 10.
- Enhanced Keywords
- The new RESTRT and METHOD attribute values have been added in the FREQUENCY_DOMAIN _ACOUSTIC_BEM keyword.
- Seatbelt Tool
- Full-meshed slipring creation has been enhanced using an embedded
simulation for robust and high quality results.
Figure 11.
Figure 12.
Resolved Issues
- In SECTION_BEAM, when the QR attribute is blank or equal to 0.0, the value is now maintained on export and not automatically switched to 2.
- When creating CONSTRAINED_INTERPOLATION, the default value of independent DOF is now set to 1.
- In specific cases, the segmentation error when reading INITIAL_STRESS_BEAM has been fixed.
