Design Explorer
New Features
Envelope Response
A new envelope response is now available for displacement responses. When selected in the microdialog during the response creation, the envelope response will report the maximum displacement value for each selected node across the entire exploration.
A new Envelope Response tab in Results Explorer will report the response values, and a corresponding envelope contour can be displayed.
Compliance Response
A new compliance response is now available for explorations using OptiStruct as a solver and can be created via the Mass/Volume Response tool.
ExpertAI
ExpertAI, previously only available within Results Explorer, is now also available as a standalone tool and can be used to reference both Design Explorer and external explorations. Now it’s possible to open and use DOEs and optimizations which may have originated outside of Design Explorer.
Enhancements
Generative Design
The Generative Design workflow can now support multiple design spaces simultaneously. Previously, you were forced to select a single design space for concept generation.
The draw direction and symmetry design variables have been updated to allow quick creation of primary planes in both positive and negative directions. Previously, only positive directions were supported. Others needed to be manually created.
Replicate Design Variables
Multiple replicate design variables can now be created at the same time by selecting multiple lines. Previously, only a single line could be selected, so replicate design variables had to be created one at a time.
Replicate design variables can be created by selecting nodes. In this special case, instance numbers will be automatically selected as 0 and 1 and cannot be changed.
For doublers and bulkheads, attributes of instances can now also be made variable. Previously, only the number of instances was variable and all properties were fixed.
Connector Design Variables
The Weld Length and Break Length attributes, which are available when a connector’s Skip Welding attribute is selected, can now be considered when creating connector design variables.
Miscellaneous Enhancements
Nominal runs are now optional. You how have the ability to select whether or not to include a nominal run in your exploration.
You are now prompted when opening a model containing explorations if the study path does not match the folder containing the opened model, and the path is automatically reconciled if desired.
Exploration evaluation now occurs in a separate thread, so you can close your HyperMesh session during evaluation if desired.
More interactive feedback is provided for failed exploration runs. By moving the mouse over a failed exploration run, error information will be displayed.
Other miscellaneous performance improvements have been done.
