Skeleton Modeling
Enhancements
- Auto-Offset Tool
- The Auto-Offset tool now supports Member Joints input.
- Member Creation and Absorb
- Member Creation and Absorb now generate sections perpendicular to the line profile.
- Joint Creation Performance
- Joint creation performance has been improved when geometry is the input.
- Skeleton Environment Workflow Help
- The workflow help has been improved within the Skeleton environment.
Resolved Issues
- The crash while performing line extract with a small resolution has been resolved.
- The slowdown when entering the Absorb tool has been resolved.
- The crash when using Section Cut with the Section Cleanup option enabled has been resolved.
- Deleting multiple joint legs in a single operation no longer deletes the related elements.
