Safety Report Manager
New Features
New Modules
  • EuroNCAP FAR Side Occupant Assessment.
  • ADR Description (part of Seat load cases).
  • ISOFIX (part of Seat load cases) is now available.
New Features in Existing Modules
  • Injury metrics for Humanetics Body Model (HBM-Connect) as part of Front impact - EuroNCAP regulations.
  • The Frontal impact > IIHS > ODB module now supports:
    • Second row left occupant injury calculations.
    • DIAdem files for physical test data.
  • Contour Plot module is enhanced to support FLD plot creation.
  • Contour Plot module can now create Derived Results on demand and apply them as a contour.
General New Features for the Safety Report Manager
  • Perform curve comparison across multiple iterations (CORA tool).
  • Append or Overlay the results and the slides in the PowerPoint PPT report during the overlay scenario.
  • Apply user-defined reader settings while loading the Radioss and LS-DYNA results.
  • Run custom scripts within the framework.
Enhancements
  • Contour plot and Animation: New modules are updated to read and apply custom legend styles.
  • A new HyperGraph default file is now supported specifically for an overlay scenario. It allows you to control the curve legend attributes, such as visibility and legend position, during the overlay process.
  • A new HyperView default file is now supported specifically for an overlay scenario. It allows you to control the curve legend attributes, such as visibility and legend position, during the overlay process.
  • Postscript functionality is enhanced with a new option to change the line style per layer from the session files loaded in HyperGraph.
  • Luggage Retention module is updated to capture animations (MP4 format) when generating the report.
  • Loadcase Description module is updated to take additional inputs for Pulse/Load and Dummy/Test equipment.
  • Energy Dissipation module is enhanced to include a summary table for each run containing Clip 3ms and 80g values.
  • Supports DIAdem (*.dat) files for physical test data.
  • Time step information is now displayed in all animations slides.
Resolved Issues
  • Contour plot > Effective Plastic Strain missing layer information issue.
  • PPT slide titles not aligned on the left.
  • Plotting pulse curves for seat load cases.
  • Tracking system settings in the Measure Plot module.
  • Element selection issue in the Energy Dissipation module.
  • The Excel limitation of 32767 characters per cell when saving the Safety Report Manager configuration file has been resolved.
Known Issues
The following known issues will be addressed in a future release as we continuously improve the software:
  • Input validation check is not supported for Battery Section Force and BOM modules.
  • Load Path, Run Statistics, and Weld Failure modules, as well as input validation check functionality, is not supported for Radioss and PAM-CRASH solvers.
