Meshing
New Features
Solid Topology Editing
Automatic mesh update is now available for CAD + mesh and FE geometry when topology editing 3D solids.
Solid topology editing is now supported for the following:
  • 3D tetra mesh and 3D tetra mesh with a 2D skin
  • First order for CAD + mesh and FE geometry
  • Second order CAD + mesh
Solid topology editing now requires full association of the nodes to the geometry.
Enhancements
Box Trim
The overall performance has been improved.
Mesh quality has been improved at trim boundaries.
Box calculation has been optimized for accuracy.
Handling of 1Ds and solid elements at box trim boundaries has been improved.
Midmesh
Automatic midmesh extraction now assigns attributes to midmesh surfaces, which enables faster alignment and easier cleanup.
The following new alignment methods have been added for more efficient midmesh adjustments:
  • Middle
  • Edge Align
  • Plane
  • Cylinder
  • Offset
  • Fuse
  • Copy
FE Geometry
Curvature based is the new method to generate topology from FE geometry. It uses curvature analysis to detect and trace surface features by evaluating how sharply the model bends. Areas with low curvature are treated as flat, while high-curvature regions are examined using principal directions to generate smooth, meaningful lines. It is controlled by three options:
  • Edge feature angle
  • Vertical filter
  • Parallel filter
Resolved Issues
  • Some bugs were resolved which has improved meshing compatibility with embedded 1Ds.
  • Some bugs were resolved which significantly enhanced the performance of Element Quality Color mode.
