ANSYS Interface
Enhancements
- RMODIF Card Supported
- Support for reading modified real constant sets.
- DMOPT
- Supported in the load step entity.
- RSTCCONTROL
- Controls whether element single value results are written to the results file. This is supported within the OUTRES card in the load step entity.
- SOLOTION
- Specifies solution transition options. This is supported in load step entity.
- RSOL and MISC
- Supported as part of the OUTRES card in the load step entity.
- RESCONTROL
- Controls file writing for multi-frame restarts.
- Analysis Cards Moved
- Analysis cards from control cards have been moved to the load step entity based on analysis type.
Resolved Issues
- Incorrect import for the SECJOINT,LSYS card.
