Calculate the OLC and Modifier
From the MPDB Projection Tool dialog, verify that the OLC &
Modifier Calculation option is checked.
Note: This option is activated by default.
Select a file type from the drop-down menu.
- T01 (Radioss file)
- Binout/Nodout (LS-Dyna)
- Use the file browser to select the requested output file.
- Enter the requested input to extract the barrier acceleration value requested for the OLC and Modifier calculation.
- Activate the Filtering check box and choose the filter options to apply on the time history outputs.
