2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
Position a dummy model using the Dummy Browser.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Use the Seatbelt Browser to create a complete seatbelt system.
Export an input deck, for the appropriate solver, in order to simulate the deformation of the seat under the dummy. The simulation result files can be imported to update the initial FE model and remove the intersections and penetrations between the dummy and the seat.
Allows you to perform a simulation of the seat foam deformation under the dummy.
Use the Barrier Positioner tool to automatically get the impact barrier into position, based on the selected crash regulation.
Use the Bus Rollover tool for the automatic recognition of the unstable position of the bus, the automatic recognition of the impact position of the bus, and the automatic creation of loadcase for impact simulation.
Use the Ejection Mitigation (EM) tool for the automatic target marking according to FMVSS-226 rules, automatic positioning of the headform impactor, and the automatic export of ready-to-run solver decks for all of the selected impact locations.
Use the Genetic Impact tool for the creation of target points on structural parts, the automatic positioning of any type of impactors on the target points, and the automatic export of ready-to-run solver decks for all of the selected impact locations.
Use the IP Impact tools to automatically calculate the instrument panel (IP) testing area according to the regulations FMVSS201 and ECE-R21, position the headform impactor, and export ready-to-run solver decks for all the selected impact locations.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal input, therefore reducing the full process lead time.
Use the Fmvss201U Marking tool to streamline the vehicle marking process by incorporating necessary input data for vehicle parts.
Use the Safety ribbon to access crash and safety post-processing tools.
The Altair Safety Report Manager (ASRM) is a fully customizable automatic report generation utility for crash and safety regulations.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
