Use the Safety ribbon to access crash and safety post-processing tools.
Figure 1. Safety ribbon in HyperView and HyperGraph
Note: The Clip option is only available
in HyperGraph.
Vehicle Crash Regulation Tools
Load Case > Front Impact
From the Load Case group, click the arrow next to the front impact icon,
, to select the following
tools:
IIHS Front (40%)
IIHS Front (25%)
MPDB (HyperView only)
Load Case > Side Impact
From the Load Case group, click the IIHS Side icon, , to display the tool.
Load Case Menu
From the Load Case drop-down menu, select the following post-processing
tools:
Compare Time History
Door Intrusion
Relative Displacement
Figure 3.
Vehicle Impact Regulations Tools
From the Impacts group, you can access the following tools:
Click the Pedestrian icon, , to access the pedestrian impact
post-processing tools for head, lower-leg, and upper-leg simulations
analysis in accordance with Euro-NCAP, GTR, and C-NCAP regulations.
Click the Instrument Panel icon, , to access the post-processing tool
for FMVSS201 and ECE-R21 regulations.
Click the Upper Interior Impact icon, , to access the post-processing tool for
Dummy Injury Criteria
From the Occupant group, select the Clip drop-down menu to
access the Injury Criteria plot macros.
Note: This option is
only available in HyperGraph.
Figure 4.
Selecting an injury criteria option displays the Math Macro dialog, where you can
define the parameters as necessary.Figure 5.
