Generic Impact
Use the Genetic Impact tool for the creation of target points on structural parts, the automatic positioning of any type of impactors on the target points, and the automatic export of ready-to-run solver decks for all of the selected impact locations.
Marking
In the Marking workflow, three methods of target points creation are available.
- Manual
- Create target points by manual locations selection on the graphic area.
- Import from file
- Create target points by importing a .csv file containing the targets information.
- Raster
- Create target points by projecting a grid of points on the structural mesh.
Manual Marking
Import from File Marking
Click
on the guide bar and select
the CSV file.
Click Mark to automatically create the Design Point
entities at the defined locations.
Figure 5.
Below is an example of a CSV file content:Figure 6.
Raster Marking
Raster marking allows you to create a grid of Design Points on selected components.
Below is an example of a 300.0x300.0 plane size and a 50.0 design points step size:
Positioning
- Calculate the position of the impactor for all of the selected Design Points
- Visualize the position of the impactor
- Export ready-to-run solver decks for all of the selected Design Points
Pre-Requisites on the Headform Model
This tool can position any type of impactors. A coordinate system at the center of the impactor with the X axis pointing in the impact direction must be defined and is used to position the impactor. Any velocity or forces on the impactor should be defined in the impactor model or in an external include referenced into the main file.
Positioning Methods
- Automatic
- Uses the positioning parameters defined in the Structural Property of each Design Point.
- Target/Angles
Figure 12.
- Normal to Target
Figure 13.
Export Solver Decks
This tool enables you to export ready-to-run solver decks for all of the impact locations, in a very short time. The tool will only calculate the transformations to apply on the impactor for each of the Design Points, depending on the selected positioning method, and add this information as include in the main model file.
- Main File
- The user-defined main input deck, containing the include structure of the final model.
- Impactor File
- Impactor deck that the tool defines as include in the main file during the export.
- Output Directory
- Location where all of the solver decks for each impact location will be written out.
During the export process, the tool generates an additional include file containing the computed transformations to apply on the impactor and refer this include file inside the main file.
