Seat Deformer (Pre-Simulation)
Export an input deck, for the appropriate solver, in order to simulate the deformation of the seat under the dummy. The simulation result files can be imported to update the initial FE model and remove the intersections and penetrations between the dummy and the seat.
When a dummy is positioned to its H-Point location on a seat, intersections between the dummy and seat foam parts generally occurs.
From the Safety ribbon, click the
arrow next to the Seat Deformer tool, and select
Seat Deformer from the menu.
Figure 1. Restriction: Only available in the LS-DYNA and Radioss solvers.The PreSimulation tool opens. - Define pre-simulation setup settings.
- Click Export.
