Unit System |
Selecting a unit system will automatically set up the default simulation
parameters to the correct unit. In any case, you can still modify these values
manually. |
Dummy |
Dummy components that are selected in contact with the seat will be exported
for the pre-simulation. The selection can be done via:
- Mechanism
- Opens a dialog to select a complete dummy
- Set
- Opens a dialog to select a set of type *SET_PART_LIST
Seat |
Select the seat components that will be exported for the pre-simulation. The
- Mechanism
- Opens a dialog to select a mechanism defining the seat. Only the bodies
that are defined by components or sets of components will be taken into
account.
- Set
Fixed Nodes of Seat |
Select the nodes that will be fixed during the simulation. The selection can
be done via:
- Set
- Opens a dialog to select a set of type *SET_NODE_LIST
Dummy Displacement Direction |
Defines the vector to move the dummy from its initial position to the final
position on the seat. |
Export Files |
Defines the pre-simulation deck name and location. |
Dummy Velocity |
Defines the imposed velocity value applied on the dummy parts during the
simulation. Default value = 0.1mm/ms. |
Time Step |
Defines the control time step value. Default value = 0.001ms. |
Scale Materials Density |
Scale factor to scale the material density values in order to increase the
critical time step of the model. Default value = 10. |
Dummy Displacement Step |
Displacement increment used to move the selected dummy components along the
prescribed vector. After each increment, the penetration check between the dummy
and seat will be performed and the dummy motion will be stopped when penetrations
are no longer detected. Default value = 10. |
Soft |
Defines the Soft parameter value in the generated contact between the dummy
and seat. Default value = 2. |
Friction |
Defines the FS parameter value in the generated contact between the dummy and
seat. Default value = 0.0. |
Imposed Contact Thickness |
Defines the value of parameters SST, MST and SLDTHK in the generated contact
between the dummy and seat. Default value = 0.0. |
Contact Stiffness Scale Factor |
Defines the value of parameter SFS in the generated contact between the dummy
Import *INITIAL_STRESS_SOLID |
If this checkbox is activated, initial stresses for solid elements will be
imported from the dynain file. This option is activated by default. |
Import *INITIAL_STRESS_SHELL |
If this checkbox is activated, initial stresses for shell elements will be
imported from the dynain file. This option is deactivated by default. |
Import *INITIAL_STRESS_BEAM |
If this checkbox is activated, initial stresses for beam elements will be
Export |
Starts the export process of the pre-simulation deck at the specified
location. |
Import dynain File |
Allows the LS-DYNA simulation to update the initial
model. |
Close |
Closes the dialog. |
