Math
Perform basic math operations on one, two, or three curves at a time.
Available operations include curve addition and multiplication and resultants, for example. The start, end, or sample frequency of the various curves is not an issue-the VST automatically crops and samples the input curves as needed. The curves must be using the same units, in most cases.
The Math Macro dialog contains options to perform on one, two, or three curves.
One Curve
- Absolute
- Given c1, a curve is created which is the absolute value of y vs. x.
- Acoustic Weighting
- Auto Correlation
- If you are comparing two curves, this function would show where the curves match in phase, where c1 and c2 are the same curve.
- Derivative
- Given c1, a curve is created that is the derivative of c1.
- Double Integral
- Given c1, a curve is created that is the double integral of c1.
- Double Derivative
- Duration
- Calculates the load versus duration for a given curve.
- Duration Comp
- Partitions the input curve into 101 bins, reporting only the negative curve values.
- Duration Tens
- Partitions the input curve into 101 bins, reporting only on the positive curve values.
- Integral
- Given c1, calculates the integral of the c1.
- Max Note
- Min Note
- Normalize
- Given c1, calculates a new curve, such that the peak value is "1".
- Normalize over Max
- Resample or Sample Points
- Resamples the given input curve to the specified data frequency.
- Reverse Curve
- Reverses a curve about the vertical axis, like a mirror.
- Square
- Calculates the square of the curve.
- Window
- Crops the curve to the given window size.
- Window Integral
- Given c1, calculates the integral of c1 over the range of the window.
- Zero
- Sets the y value in a given range to the user-defined constant.
- g>>mph
- Integrates acceleration curve to obtain velocity.
- g>>inch
- Double integrates an acceleration curve (given in g’s and seconds) to a displacement (given in inches and seconds).
- mph>>g
- Given c1, a curve is created that is the derivative of velocity to acceleration, while converting MPH to g's.
Two Curves
- Add
- Adds two curves.
- Average
- Averages two curves.
- Cross Correlation
- Given c1 and c2, a curve is created which is the cross correlation between the y vectors of c1 and c2.
- Cross Plot
- Given c1 and c2, this function plots c1.y as x and c2.y as y of a new curve.
- Divide
- Divides two curves. If c2 has zero values, this will fail.
- Divide with Zero
- If c1 is divided by c2, and if c2 has any zero values, then c1/c2 equals 0.
- Multiply
- Multiplies two curves.
- Resultant
- Given c1 and c2, calculates the square root of (c12 + c22).
- Subtract
- Subtracts two curves.
Three Curves
- Add
- Adds three curves.
- Average
- Averages three curves.
- Multiply
- Multiplies three curves.
- Resultant
- Given c1, c2, and c3, calculates the square root of (c12 + c22+c32).
