Upper Interior Impact
The Upper Interior Impact tool facilitates the post-processing of the FMVSS201U analysis.
This tool uses time-history and result files as input and automates the post-processing with minimal input, therefore reducing the report generation lead time.
In HyperView or HyperGraph, from the Safety ribbon > Impacts tool group, click the Upper Interior Impact tool to invoke the Upper Impact Post dialog.
Note: The Upper Interior Impact tool is not supported for the HyperView - MultiCore profile.
Figure 2. Upper Interior Impact Post dialog
  1. Configuration (Solver Selection)
    Supported solvers are Radioss, LS-DYNA, and PAM-CRASH 2G.
  2. Target csv
    Select the HyperMesh-created *.csv file.
  3. Full vehicle model
    Select the solver input file that contains the Upper impact trims model or Full vehicle model containing Upper impact interior parts and Outer BIW components.
  4. Result directory
    Select the root directory that contains the analysis directories as sub-directories.
  5. Units
    Select the model units from the drop-down menu.
  6. HIC(d)
    Select the acceleration data from the output file for the HIC(d) curve.
    Select the sub case, Y Type, Y Request, and Y Component.
  7. Threshold/Limit Values and Color Selection
    Define the limit values and colors.
    • Click the color palette to select the color.
    • Define the limit/threshold values in the value field.
    • Select the HIC(d) value or the impact location name for summary.
    • Use Reset to restore the default values and colors.
  8. Head Displacement
    Select the displacement data from the output file for the displacement versus time curve. Select the sub case, Y Type, Y Request, and Y Component.
  9. Parallel sessions
    Select the number of batch processes to launch. For example, if processing 200 impact locations, the number of parallel processes are launched to reduce processing time.
  10. Home button
    Click to return to the summary page.
  11. Summary
    Select the impact locations to post-process in the summary page:
    Figure 3.
  12. Compare
    Click Compare to select the impact locations to be processed using the Select compare options:
    • Select folder to compare: From the file browser, select multiple analysis folders to be compared.
    • Select notes to compare: Select multiple notes on the summary window to be compared.
  13. Detailed Session
    Click Detailed Session to select the impact locations to be processed through the Select target points window. For each selected target point, a page is generated with the following results:
    Figure 4.
  14. Report
    Run Statistics: Run a summary of the Normal versus Error termination per impact location:
    Figure 5.
    Overall Summary: Summary table of the HIC(d) value and maximum displacement for all selected impact locations.
    Figure 6.
    Overall Injury Map: HIC(d) value on the Upper interior parts.
    Figure 7.
  15. Point Selection
    From List: Select the impact points from the list to create the detailed report for.
    From Notes: Select the impact points from the modeling window by selecting the notes to create the detailed report for.
  16. Report per Impact
    A detailed slide for all selected impact points is created in the report.
    Figure 8.
  17. Report Directory
    The report directory where the consolidated report PowerPoint file is saved.
  18. Report
    Click Report to generate the final PowerPoint file. The setting icon opens the report settings.
  19. File Browser Folder and Save
    Save or import a configuration file containing all defined setups.
