- Results Database
A results database contains translated results files, which are read into HyperMesh for post-processing.
- Import Result Files
Import analysis result files to create plots, query results, and so on.
- Results Browser
Use the Results Browser to review and manage results and plots.
- Create, Edit, and Display Contour Plots
Use the Contour tool to visualize result data by coloring entities by value, allowing for easy identification of maximums and minimums throughout the model.
- Create, Edit, and Display Vector Plots
Use the Vector tool to draw arrows such that the direction in which the arrow points is the direction of the vector and the length of the arrow is its magnitude.
- Create, Edit, and Display Tensor Plots
Use the Tensor tool to show stress and strain directions and magnitudes for various solvers from elemental values.
- Create, Edit, and Display Deformed Plots
Use the Deformed tool to specify parameters for deformation display.
- Create, Edit, and Display Marker Plots
Use the Marker tool to visualize result data by adding text on entities by ID and value, allowing for easy reference of result values on selected entities.
- Contour Beam Stress
Use the Beam Stress tool to display a contour of stress distribution on a tessellation of a beam cross section.
- Create, Edit, and Assign Custom Legends
Use the Legend entity to create, edit and assign custom legends to any contour, vector and tensor or marker plot. Legends can be numeric, or category based. It can be copied or saved to an external file and imported for re-use.
- Plot Results from Legend
Change properties directly in the legend to drive result plotting and change data type, component, layer, averaging method, and so on. This is possible in contour, vector, tensor, and marker plot legends.
- Create and Edit Charts Using Results
Create charts using the data read from a results file by directly reading a result datatype, or by tabulating the data in the Matrix Browser.
- Free Body Diagram (FBD)
Calculate free-body forces, moments, displacements, and rotation.
- Results Processing Tools in HyperMesh
Seamlessly process solver native results in HyperMesh.
- Matrix Browser
Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
- Solver Interface Specific Behavior
Solver-specific behavior includes deviations from or additions to the standard post-processing features.
