Create, Edit, and Display Tensor Plots
Use the Tensor tool to show stress and strain directions and magnitudes for various solvers from elemental values.
Restriction: Only component display mode is
                    currently supported.
                From the Post ribbon, click the Tensor tool.
 - Select a tensor plot using the drop-down menu on the guide bar.
 - Optional:
                Click the Create Tensor satellite icon to define a new
                    tensor plot.
 - Optional:
                To review and edit the current plot definition, click
 on
                    the guide bar.
             - Optional:
                Select a subset of components or elements on which to apply the plot.
                By default, the plot is applied to the entire model.
 - Click Plot to display the plot.
                Click one of the following:
 - Save changes and exit the tool
 - Clear the plot
                        Exit the tool without saving changes
Tip:
        - Plots are based on the current load case and step, which can be reviewed and updated from the status bar or the browser.
 - Existing plots can also be displayed or cleared using the plot icons in the Results Browser.
 - Editing the definition for a displayed plot will automatically update the graphics. For large models, editing the plot definition may be faster if the plot is not displayed.
