Create, Edit, and Display Deformed Plots
Use the Deformed tool to specify parameters for deformation display.
                From the Post ribbon, click the Deformed tool.
 - Select a deformed plot using the drop-down menu on the guide bar.
 - Optional:
                Click the Create Deformed satellite icon to define a new
                    deformed plot.
 - Optional:
                To review and edit the current plot definition, click
 on
                    the guide bar.
             - Optional:
                Select a subset of components or elements on which to apply the plot.
                By default, the plot is applied to the entire model.
 - Click Plot to display the plot.
                Click one of the following:
 - Save changes and exit the tool
 - Clear the plot
                        Exit the tool without saving changes
Tip:
            - Plots are based on the current load case and step, which can be reviewed and updated from the status bar or the browser.
 - Existing plots can also be displayed or cleared using the plot icons in the Results Browser.
 - Editing the definition for a displayed plot will automatically update the graphics. For large models, editing the plot definition may be faster if the plot is not displayed.
- Selection
 - When a deformation plot is active, window selection is disabled.
 - Tensor and Vector on Deformed
 - Vector and tensor are currently always shown in undeformed shape. If
                            deformation is on and either a tensor or vector plot are displayed, an
                            undeformed shape (with default component color mode) is displayed and
                            relevant quantities are drawn using it as reference.
Figure 3.
