Contour Beam Stress
Use the Beam Stress tool to display a contour of stress distribution on a tessellation of a beam cross section.
Stress distribution is recalculated from vectors “1D Forces” and “1D Moments” datatypes at first section (node 1) of a beam. It does not use any stress recovery points from solver output.
You can control which of the force’s contributions to consider during the stress calculation.
Stress is calculated using Elasticity theory (reference: Analysis and Design of Elastic Beams: Computational Methods, Walter D. Pilkey).
Restriction:
- Property must refer to either a Standard or Solid beam section.
- A tessellation of the section is generated on-demand to display the stress contour.
- The result file needs to include vector datatypes “1D Forces” and “1D
Moments”.
- OptiStruct native *.h3d lacks such vectors and will not work.
- *.op2, *.xdb file, or any translation in *.h3d file will work.
- Currently, only the resultant force/moment at the first node of a beam is considered during the stress calculation.
From the Post ribbon, click the Beam Stress tool.
Figure 1. - Select 1D elements on which to calculate stress.
Use the drop-down on the guide bar to select the stress
quantity to evaluate.
Shear Y and Z are with respect to the elemental system.
Figure 2. Von Mises Stress on Selection -
Select force and moment in the microdialog.
The selected stress quantity is calculated from the forces and moments contributions acting on first node of the beam element.
Selected beams can be contoured all at once by clicking
on the guide bar. Otherwise, clicking Find enters a model tour with prev/ next options to navigate across the selection.
During the model tour, the option Normal view automatically sets the view normal to the section and fits the view on the element. -
Set display options by clicking
on the guide bar.
- Mesh mode
- The default stress calculation is performed using a meshed section.
- Scale Factor
- If beam sections are small compared to the model size, it is possible to scale them.
- Contour Type
- Display contour on Element (default) or on Node (see Figure 8).
Changing any of these options or force contributions/subcases will auto-update the active contour.
