Use the Legend entity to create, edit and assign custom legends to any contour,
vector and tensor or marker plot. Legends can be numeric, or category based. It can be
copied or saved to an external file and imported for re-use.
To create a legend:
Right-click in open space in the Results Browser.
Select the desired configuration from , Vector, or
Tensor.
For Contour/Vector/Tensor, select the desired type: numeric or
category.
For vectors and tensors, a category legend is used to display the plot
by direction.
For contour, two types of category legend are supported.
- Category: this type of category legend is automatically created
and displayed for the following contour plots as these results
are discrete values.
- MaxLayer or MinLayer plot
- Contour plot of Envelope Trace datatype
- Contour plot of Contact Status datatype output by
OptiStruct or Abaqus
Note: This type of category legend cannot be directly
created from the Results Browser.
However, once it is displayed in the modeling window, it can be saved from the
right-click context menu and an
entry will be listed in the Results Browser under the Legends
folder.
- Custom_Category: this is a special type of legend you can use to
define a table of value ranges and corresponding category labels
and assign it to any numeric result. For example, if you have a
stress contour with values from 0-100 MPa and group them into
categories ranging from critical to low, you can create a table
as follows.
- 80-100: Critical
- 50-80: High
- 20-50: Medium
- 0-20: Low
Once this legend is assigned to the plot control, the
stress contour is automatically updated to color based on categories.Note:
- Custom category legend can also be created by
right-clicking on the numeric legend in the modeling window and selecting
Make Category Legend. A
4-level legend with default labels is created based
on the numeric range of the result. This action also
automatically links it to the displayed plot.
- The default labels are Critical, High, Medium, Low.
Additional levels are created with labels as
Category-n.
- Care should be taken when specifying ranges. Make
sure the max value of a category matches the min
value of the next category, and the table covers the
entire range of the result data.
- The initial numeric range of the result is not
remembered. This means that any reset operation will
not restore the range to original values.
- To revert to the original numeric contour, unlink
the legend from the plot control.
For Marker plot, the legend cannot be directly created from the
Results Browser. However, once it is displayed
right-click context menu and an entry will be
folder.
- Alternate methods to create a legend
- Right-click on a legend in the modeling window and select
Save Legend to create a new
legend. This legend is automatically linked to the displayed
plot.
- Right-click on the Legend folder to import an
.xml file containing a legend
definition. If a legend with the same name already exists,
the imported legend is renamed with the prefix
importedlegend_.
To edit a legend:
Use the Entity Editor to edit the legend
properties such as format, precision, range, color scheme, and
position.
Alternatively, use the graphics legend context menu to change some of the legend
properties.
This automatically updates the linked legend entity.
Note:
- Format and Precision are supported only for numeric legends.
- Range can be set to automatic, or user-defined.
- If automatic, the values of the legend are not editable and
are directly obtained from the linked plot definition. If
user-defined, values can be changed using the values table
or by clicking directly on a value in the graphics
legend.
- Due to current graphics legend limitations, certain value
inputs may not be accepted. It is thus recommended to enter
values in a strictly descending or ascending order.
- If custom values are entered and then the number of levels
are changed, values get reset. It is thus recommended to
first set the number of levels and then input values.
- Color Scheme can be Divergent, Rainbow, or User-defined. If
User-defined, change the color of any level by clicking directly on
the color in the graphics legend.
- Existing plots can also be displayed or cleared using the plot icons
- Editing the definition for a displayed plot automatically updates
the graphics. For large models, editing the plot definition may be
faster if the plot is not displayed.
To assign a legend:
Click on a plot definition in the Results Browser
to access the Entity Editor, or, open the
Contour/Vector/Tensor tool, pick a plot definition from the drop-down
menu on the guide bar, then click .
Select Custom Legend.
Click Legends and select from existing legends
using IntelliSearch or the Advanced Selection
dialog.
The list shows only legends of the same config.
To remove a legend and revert to default legend, clear
Custom Legend.
