NVH Menu
The NVH menu provides you with access to various NVH utilities.
To use the HyperView NVH utilities, you must first load the NVH
preferences file:Figure 1.
![](../../images/post_processing/nvh_grid_part_preferences_dialog.png)
- From the File menu, select Preferences dialog is displayed. . The
- From the Preferences dialog, select NVH-Utilities and click Load. The NVH menu is added and displayed on the menu bar.
From the NVH menu, you can select the following options:
