2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
Use the Notes tool to label items, describe trends, and relate additional information.
Use the Tracing tool to trace system, component, and node entities during animation.
A new workflow emphasizing the multicore profile for post processing results from certain solvers and crash use cases.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
