2026
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
Symmetry visualization allows partially modeled geometry to be shown in full extent by reflection and/or duplication or in the case of axisymmetric models, by 3D geometry generation.
Use the Explode tool to explode a model or selected components for improved visualization.
A new workflow emphasizing the multicore profile for post processing results from certain solvers and crash use cases.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
