TeimOrbit 2D Road Type: plank or cleat
If the ROAD_TYPE is set to cleat, COSIN/road searches and reads the following data items in
the [PARAMETERS] section:
Name of input variable | Unit | Meaning |
height | length | Height of plank/cleat. |
start | length | Start of plank/cleat (travel distance). |
length | length | Length of plank/cleat, measured along x axis. |
bevel_edge_length | length | Length of bevel edge, measured along x axis. Bevel edge has 45 degree slope. With edge_rounded = 1, rounded corners instead of bevel edges are used. In this case, bevel_edge_length is the radius of the corner. |
edge_rounded | 0/1 |
direction | angle | Direction of plank/cleat relative to y axis. direction = 0 if plank/cleat is placed crosswise. |
mu_factor_cleat | - | Friction value factor on plank/cleat. |
