TeimOrbit 2D Road Type: flatbelt
The rotating flatbelt testrig is implemented as a 2D road type. If the ROAD_TYPE is set to
flatbelt, COSIN/road searches and reads the following data items in the [PARAMETERS]
section:
Name of input variable | Unit | Meaning |
number_cleats | - | Number of extra cleats on belt (number_cleats = 0 allowed) |
cleat_direction | angle | Direction of cleat relative to belt lateral direction. Direction is zero if
cleat is oriented exactly in transversal direction. Direction angle is measured
counter-clockwise if looking from above onto the belt surface. Default value is 0 (transversal cleat). |
mu_factor_cleat | - | Friction modification factor on cleats. |
The flatbelt speed is defined by one of the following alternatives:
Either:
v | ||
v | length/time | Constant rotation speed of drum surface. |
acceleration_time | time | Time span at beginning of dynamic simulation, to accelerate belt from
stand-still to nominal velocity. Default value is 0. |
Or:
data sub-section (TV_DATA) | Arbitrarily many lines with 2 values of type: time, length/time | Data pairs defining speed-vs.-time data of the belt’s time-dependent surface
speed profile. t values (first value in each line) should be in ascending order. |
The exact geometry of the cleat is defined by one of the three following alternatives:
Either:
cleat_height | length | Height of cleats. |
cleat_length | length | Length of cleat, measured in circumferential direction of belt. |
cleat_bevel_edge_length | length | Length of bevel edge of cleat, measured in circumferential direction of belt. Bevel edge has 45 degree slope. |
cleat_edge_rounded | - |
Or:
data sub-section (XZR_DATA) | Arbitrarily many lines with data of type: 3 x length | Data triples defining x and z data of the cross section of the cleat, together with rounding radii in these data points. Rounding radii may be zero. x values should be in ascending order. First and last y value should be zero. |
Optionally, the exact height geometry of the stoppers can be specified by spline
data:
data sub-section (stopper_geometry) | Arbitrarily many lines with data of type: 2 x length | Data pairs defining x and z data of the stoppers. x values must be non-negative and ascending: x = 0 refers to the start in longitudinal direction of the stopper. |
