Superposition of TeimOrbit 2D Roads with 3D Roads
All TeimOrbit 2D roads can be superimposed by a triangularized or RGR-type 3D road. This is
achieved by specifying the name of the respective 3D road data file in the data section
[MODEL] of the 2D road data file. This technique, for example, can be used to define a
non-flat hydraulic test-rig cylinder surface by means of RGR data:
Name of input variable | Unit | Meaning |
superimpose_data_file | - | Name of the 3D road data file (triangular or RGR type) to be superimposed to the 2D data. |
