Road Profiles and Obstacles in TeimOrbit Format
If COSIN/road recognizes the road data file is in TeimOrbit format (typically, the file name extension is rdf), it branches into the respective reading and evaluation routines.
The following sections describe the road types available in this format:
- TeimOrbit 2D Road Type: drum
- TeimOrbit 2D Road Type: flatbelt
- TeimOrbit 2D Road Type: hydraulic_test_rig
- TeimOrbit 2D Road Type: plank or cleat
- TeimOrbit 2D Road Type: pot_hole
- TeimOrbit 2D Road Type: ramp
- TeimOrbit 2D Road Type: roof
- TeimOrbit 2D Road Type: sine
- TeimOrbit 2D Road Type: sine_sweep
- TeimOrbit 2D Road Type: stochastic_uneven
Note: The most important road types are: drum,
flatbelt, hydraulic_test_rig, and
stochastic_uneven.
Please refer to the original documentation for the TeimOrbit syntax rules, as well as the meaning and content of all other data sections not documented here.
